MY JP06
Re: MY JP06
Post by yj87jp » February 26th, 2013, 4:07 pm
This radio has PA function
Re: MY JP06
Post by yj87jp » March 28th, 2013, 3:38 pm
Just wanted to give a quick updat to what I've been doing to the jeep
Replaced valve cover gasket
Filled tranfer case
Changed oil with Royal Purple 10W-30 :D (expensive but worth every cent)
Re: MY JP06
Post by yj87jp » April 4th, 2013, 3:59 pm
Just restored my hood tie downs in a fresh coat of black for the premeire tomorrow
Re: MY JP06
Post by yj87jp » May 8th, 2013, 8:03 pm
Just put my new power master 140 amp alternator on after my old one finally died, it's absolutely amazing brought new life back to the jeep
jbc455
Re: MY JP06
Post by jbc455 » May 8th, 2013, 9:38 pm
Alternator's on my list to check as the dash voltmeter only reads 12 volts while running. I'll put a real meter on the battery first.
Re: MY JP06
Post by yj87jp » May 16th, 2013, 6:49 am
I just put some new cheapo oem style fog lights on and polished the jeep. It nice because my jeep already came from the factory with the optional fog lights so the wiring and switch were already there
jbc455
Re: MY JP06
Post by jbc455 » May 16th, 2013, 8:56 am
I think I have an extra front side marker lens if you need one.
Re: MY JP06
Post by yj87jp » May 16th, 2013, 2:38 pm
That's ok I have one on order, thanks though
jbc455
Re: MY JP06
Post by jbc455 » May 16th, 2013, 3:30 pm
Ok. Hey, what part number alternator did you get?
Re: MY JP06
Post by yj87jp » May 16th, 2013, 4:19 pm
Powermaster 140 amp altenator in black thermal coat
Part # 57902
But mine is for a Cherokee cause that's where the motor came from so the wrangler one is probably different look on quadratec
and if you plan on adding extra lights,winch,etc I highly recommend going for the high amp altenator
