MY JP06
Re: MY JP06
Just wanted to give a quick updat to what I've been doing to the jeep
Replaced valve cover gasket
Filled tranfer case
Changed oil with Royal Purple 10W-30
(expensive but worth every cent)
Filled tranfer case
Re: MY JP06
Just restored my hood tie downs in a fresh coat of black for the premeire tomorrow
Re: MY JP06
Just put my new power master 140 amp alternator on after my old one finally died, it's absolutely amazing brought new life back to the jeep
- jbc455
Re: MY JP06
Alternator's on my list to check as the dash voltmeter only reads 12 volts while running. I'll put a real meter on the battery first.
Re: MY JP06
I just put some new cheapo oem style fog lights on and polished the jeep. It nice because my jeep already came from the factory with the optional fog lights so the wiring and switch were already there
- jbc455
Re: MY JP06
I think I have an extra front side marker lens if you need one.
- jbc455
Re: MY JP06
Ok. Hey, what part number alternator did you get?
Re: MY JP06
Powermaster 140 amp altenator in black thermal coat
Part # 57902
But mine is for a Cherokee cause that's where the motor came from so the wrangler one is probably different look on quadratec
and if you plan on adding extra lights,winch,etc I highly recommend going for the high amp altenator
Part # 57902
