Manny's JEEP 12 build
Re: Manny's JEEP 12 build
Post by ImperialTrooper » May 12th, 2013, 10:17 pm
Figured it was time to upgrade the rear fogs.
The button that holds the strap had come loose, that's now fixed.
My parking tag disappeared. I redesigned it and will attach it on the day of the event.
Post by raptorwrangler » May 15th, 2013, 9:57 am
Those rear fogs are looking good! How did you end up wiring them up? Through the brake light housing or the body?
-Completed Conversion..............|!\\.|@|\-\--¬[llllll]-
Post by ImperialTrooper » May 15th, 2013, 10:24 am
raptorwrangler wrote:Those rear fogs are looking good! How did you end up wiring them up? Through the brake light housing or the body?
According to the movie jeeps they were wired through the body. So I did it that way. It's also much easier in my opinion.
Post by heartyfield » May 15th, 2013, 10:50 am
Did you just ground it to the metal inside the tail light?
Post by ImperialTrooper » May 15th, 2013, 1:19 pm
heartyfield wrote:Did you just ground it to the metal inside the tail light?
The bolt should act as a ground. My previous light had 2 wires, one for positive and the other ground. I have yet to wire the new ones since the connectors were different. Ill try tonight to see if it grounds properly.
Post by COBrian » May 15th, 2013, 1:37 pm
the lights I got (not screen accurate but close) have only 1 wire. they are grounded through the mounting lug.
Post by ratrace427 » May 15th, 2013, 1:59 pm
I like the new lights and that you wired them through the tub. Exactly the way i would have done it. Good work sir!
Post by ImperialTrooper » May 17th, 2013, 1:10 am
I did find my old parking tag (left). I'm glad I had lost it. Forced me to get off my butt and redo it accurately. Notice the pixelation on the left and the wrong font was used.
Post by ratrace427 » May 17th, 2013, 1:13 am
That old one has seen some use and the new one looks great! I was thinking about buying a new one off of ebay. The quality of mine is getting worse from use as well.
Post by ImperialTrooper » June 23rd, 2013, 12:38 pm
Lazy Sunday
