The button that holds the strap had come loose, that's now fixed.
My parking tag disappeared. I redesigned it and will attach it on the day of the event.
According to the movie jeeps they were wired through the body. So I did it that way. It's also much easier in my opinion.raptorwrangler wrote:Those rear fogs are looking good! How did you end up wiring them up? Through the brake light housing or the body?
The bolt should act as a ground. My previous light had 2 wires, one for positive and the other ground. I have yet to wire the new ones since the connectors were different. Ill try tonight to see if it grounds properly.heartyfield wrote:Did you just ground it to the metal inside the tail light?
Users browsing this forum: Bing [Bot] and 38 guests
