Pennsylvania Jeep #12
- Jack_Fauth
Re: Pennsylvannia Jeep #12
can't wait to mess around with these tomorrow in the dark...!!!!
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- mydigitalvoid
Where did you mount the switches on the inside?
- Maverick20
what about the inside of the light bar how did u stop rust?
1995 YJ Sahara
- Jack_Fauth
I think the bar will be fine as it is, mine has zero rust on the inside.Maverick20 wrote:what about the inside of the light bar how did u stop rust?
as for mounting the switches i ran each lights wire through the hole in the back of the bar near each mounting tab.
then i drilled a 1" hole into of the side of the jeep that goes into the passenger compartment. Then i ran all 4 wire through a grommet and into the interior compartment. Here you can see that i mounted the switches to the oh shit bar above the glove box
Ran all 4 light to the accessory switch in the fuse box under the dash. LightS all run indepently as they did in the movie
here is a photo of the switches mounted. I think i will get a blank cover to fill in the end and hide the rest of the wires
Last edited by Jack_Fauth on December 23rd, 2011, 9:40 am, edited 1 time in total.
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- Jack_Fauth
MONEY SHOT......!!!!!!!!!!!!!
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- fantomas
Holy crap that looks great! When you test it out, let us know the actual functionality of those lights are.
On a side note, I've got that same Ikea lamp
- PaulRevere1991
looks awsome
I actually just had an idea for your glovebox delete pannel. you should try to do a Data plate for it. Until the late run of Cj5s, jeeps came with acid etched Data plates. I
here are some samples I made
04' Wrangler Sport
42' Ford GPW
42' Ford GPW
Jedigreedo
Awesome work, Fauth! Looks fantastic!
And nifty idea, Breven.
"We came, we saw, we conquered, we... woke up!"
- Maverick20
cool nice light bar im powdercoating mine the only thing im a little lost on is how to wire the lights up. like relays fuses and all that.. i know how to do butt connectors and stuff like that. just dont undersatand the route and where i need to run it all. mine will be non-morotized 55w each 4 lights.
1995 YJ Sahara
