Manny's JEEP 12 build
Post by ImperialTrooper » September 22nd, 2011, 1:13 am
This thread will be updated with any progress made or lost on my JP 12 build.
After a long search I have found and settled on a 1992 Jeep Wrangler Sahara 4.0L Auto
09/16/11 - Bought Jeep for $6500
Re: Manny's JEEP 12 build
Post by ImperialTrooper » September 22nd, 2011, 1:15 am
09/18/11 - Made a JP 12 mirror tag for $5
Post by ImperialTrooper » September 22nd, 2011, 1:17 am
09/20/11 - Heater hose ruptured on the way to work. Replaced both hoses for $7
Post by ImperialTrooper » September 22nd, 2011, 1:22 am
09/21/11 - Purchased another passenger side mirror from eBay, since mine is loose. Also purchased an accurate base plate to convert to a Jurassic Park license plate.
Post by ImperialTrooper » September 25th, 2011, 12:59 pm
09/25/11 - Discovered a crack on the headers. Possible exhaust leak. Will get a shop to weld it back up. Also found two oil leaks. One from the rear differential, and one from the auto transmission pan.
Post by Railtech » September 25th, 2011, 8:12 pm
Make sure the leak is from the pan, mine looked that way but it was coming from the rear output seal for the most part and some from the shift linkage. My pan was leaking too, but moreso from that rear transmission output seal.
Post by ImperialTrooper » September 25th, 2011, 11:09 pm
09/25/11 - Changed the auto trans filter and put a new gasket and oil.
Last edited by ImperialTrooper on September 28th, 2011, 10:11 pm, edited 1 time in total.
Ecto-DMC
Post by Ecto-DMC » September 26th, 2011, 5:08 pm
keep it up and you will have this done sooner than you think :D
Post by ImperialTrooper » September 26th, 2011, 8:02 pm
I could have it done a lot sooner, but there are a few issues with the car that are hindering progress. I got a quote from my shop... $300 for parts and labor to remove the headers and re-weld it. And there are some bad squeaking noises when I drive and I can't figure them out. I am gonna go back to my VW as my daily driver until the jeep is fully up to date on fixes and maintenance. :(
Post by ImperialTrooper » September 28th, 2011, 10:11 pm
09/28/11 - Replaced the passenger side mirror because it was loose. Found out that the TJ mirrors have a slightly different base so I'll be stopping by the Jeep dealership tomorrow to pickup some longer bolts to accommodate for the extra length needed.
