Grnjp88's '93 Sahara #28
grnjp88
Re: Grnjp88's '93 Sahara #28
Post by grnjp88 » January 3rd, 2010, 9:53 am
Cyrix9445 wrote:I get some rubbing when the wheel is turned almost to full-lock, but I hear you can just put some washers on the stops to prevent that.
My tires rubbed the same way until I used the washers on the steering stops. Now everything clears just fine. You should be okay running 31s as long as your stock springs are in good shape.
1993 Jeep Wrangler Sahara °lllll°
1969 VW Beetle Sedan (O\U|U/O)
Post by Cyrix9445 » January 3rd, 2010, 1:43 pm
Nice toys!
MN-cherokee
Post by MN-cherokee » January 8th, 2010, 10:22 pm
Where did you order your Jeep Key blank?
Brian
grnjp88
Post by grnjp88 » January 8th, 2010, 11:32 pm
grnjp88
Post by grnjp88 » January 8th, 2010, 11:35 pm
Got news that the engine arrived yesterday. I'm having the Jeep towed out to the shop on Wednesday for the transplant. If all goes according to plan, this should be my last Jeep-less weekend and I can get back to the JP build! :D
~Kyle
MN-cherokee
Post by MN-cherokee » January 9th, 2010, 1:06 am
Good to hear about the engine! Thanks for the link!
Brian
yohan-rosso
Post by yohan-rosso » January 9th, 2010, 3:24 pm
same thing happened to me, no warning whatsoever. i missed half an Alice Cooper concert. driving along with my girlfriend, my best friend and his girlfriend and sudenly BLAMMMO! i couldn't see him next to me. probably one of the most terrifying experiences in my life ;____;
MN-cherokee
Post by MN-cherokee » January 12th, 2010, 11:15 pm
Question for you guys with larger than stock tires. How did you get them to mount to the factory spare tire carrier? I just put some 235/75/15s on my YJ tonight and I used one of the older 235/70/15 as a spare and it will not fit. It hits the rubber bumpers before there is even enough to get the lug nut started. Am I missing something here?
Brian
Post by Cyrix9445 » January 13th, 2010, 11:31 am
I have a small spare on mine now, but I figure I'll use a wheel spacer to fit a 31". But I hear that it can cause stress on the hinges due to the bigger tires being much heaver. :/
Users browsing this forum: No registered users and 40 guests
