Pennsylvania Jeep #12
PaulRevere1991
Re: Pennsylvannia Jeep #12
Post by PaulRevere1991 » July 26th, 2011, 7:59 pm
I just used regular plastic paint on my center consle, turned out great.
Post by Jack_Fauth » July 29th, 2011, 1:02 pm
a little more progress, got a complete top with all the hardware including upper doors off craigslist . sorry for the crappy picture it finally started to rain so the jeep is in the garage.
Also painted the front wheels.
This weekend we will be replacing the cracked exhast manifold....joy joy...
all painted and ready to install
mydigitalvoid
Post by mydigitalvoid » July 29th, 2011, 1:34 pm
Looking good!
Post by Railtech » July 29th, 2011, 2:54 pm
Put one of those on mine, it works well. Watch that back stud, I ended up snapping mine off when I was torquing it down. That was fun welding on a nut to pull the old stud. Don't do that :).
kbb0625
Post by kbb0625 » July 31st, 2011, 7:06 pm
Did you just spray that with black spray paint or is it something a little more durable?
Post by Jack_Fauth » August 1st, 2011, 7:43 am
the mainfold is stainless so i really didn't need to coat it at all but i wanted it black so i hit it with 1600 degree high heat header paint.
Everything went well on the manifold replacement except where the power steering pump bolts to the intake maniflod. When we were taking out the bolts we noticed the one tab that the pump mounts to was completely broken. Now the bearing on the pump screeches at start up since there is only one bolt holding it now instead of two.
Just got a used intake off e-bay and it looks like i will be changing that out this weekend.
It never ends...does it.
Post by Jack_Fauth » August 2nd, 2011, 12:14 pm
last night i worked on the only rust on old #12. Looks like it was in a fender bender a few years back and was not properly repaired. i ground out all the old body work and took it all down to bare metal, then got rid of all the surface rust and metal prepped the area. Then i pounded out the dent and hit it with some bondo and light sanding. it is all straight again and no rust.
here are the before and after shots
this is how i bought it....
during the repair.....
and after......
now it just needs finish sanding and primer sealer.
jamespero
Post by jamespero » August 2nd, 2011, 1:37 pm
Nice work!
James Pero
1995 YJ Sahara, 4.0L 5spd
kbb0625
Post by kbb0625 » August 2nd, 2011, 9:15 pm
Beautiful! Muchh better. Looking back now with my jeep I wish I had paid more attention to all the little dings and details that I just kind of blew over... So kudos to you for taking your time!
Ecto-DMC
Post by Ecto-DMC » August 3rd, 2011, 10:35 pm
Yeah god is in the details and if you plan to keep the Jeep then Do it right and do it to the best of your ability and Wallet :mrgreen:
Looks good your doing a great job keep it up :D
Users browsing this forum: Bing [Bot] and 119 guests
