Kytor Industries JP17
KytorIndustries
Re: Kytor Industries JP17
Post by KytorIndustries » September 10th, 2017, 8:45 pm
My neighbors must love me.
Kytor Industries
kytor.com
KytorIndustries
Post by KytorIndustries » October 29th, 2017, 11:41 am
Kytor Industries
kytor.com
Chase65
Post by Chase65 » November 3rd, 2017, 12:35 am
Bet you had a fun halloween!
1993 YJ Sahara
1994 Explorer Limited
2004 Mercedes ML350
KytorIndustries
Post by KytorIndustries » August 11th, 2018, 9:54 am
Some updates on repairs/upgrades.
After having a rear brake line rot out, I replaced all of the lines and flex hoses with stainless steel; filled with dot4 and flushed/bled the system. Also replaced the rear brakes cylinders and hardware.
Added a cooler to the props:
Replaced the bump stops with new:
New plugs, distributor and plug wires, last time they were changed was 65 million years ago:
New heavy-duty powder coated gas tank skid plate:
New steering stabilizer, the old one was a gigantic bitch to get out (tapered bolt), it went through some nice plastic deformation before finally popping loose, then cut it when an angle grinder to get it out:
I have a lot on my list downstream. Next up is to replace the old leaf springs and shocks with newer/better quality ones.
Kytor Industries
kytor.com
Post by ratrace427 » August 11th, 2018, 3:26 pm
that is some hard but satisfying work. You have been busy.
JP Junkie
Post by JP Junkie » August 11th, 2018, 6:52 pm
Great work dude. Prolly too late, but if you're looking for a replacement fuel tank mat, I got mine from here for about $30:
https://www.detroitmuscletechnologies.c ... 90-rubber/
KytorIndustries
Post by KytorIndustries » August 12th, 2018, 7:37 am
JP Junkie wrote:Great work dude. Prolly too late, but if you're looking for a replacement fuel tank mat, I got mine from here for about $30:
Thanks. I actually tossed the old mat and am running without one. Eventually I'll drop it again and put a new mat back in, but it's not going to hurt anything in the short term.
Kytor Industries
kytor.com
Users browsing this forum: Google [Bot] and 60 guests
