This is an understatement lolratrace427 wrote:I noticed lots of little details missed on the new jeep builds
It was
light bar apart, light tabs removed and spot putty added to the imperfection areas
//uploads.tapatalk-cdn.com/201806 ... a9dc48.jpg
It was
radiant fire minus the flat clear //uploads.tapatalk-cdn.com/201806 ... 00d761.jpg
It was
RustyRodder wrote:Aw man, i really like the rustic look fo these Jeeps.
the rusty look is the only way to be different now.
Adding photos with tapatalk causes problems. If you open the image in a new tab then it pulls up the photo just fine. Is there a way to change the image size and fix the issue?
installed a new stainless spring for the whip. The chrome ones only last two years. Removed the seats for transport to the upholstery shop and sanded one side worth of fender flares.
Sucks that the inner fenders are rotten. They are falling apart in my hands but sourcing new ones will be a challenge. Ones from a salvage will most likely be just as brittle. maybe mother mopar has some available in her vintage parts warehouse.
Cleaning up nice. Vacuumed up the southern Missouri dust out of the carpet.
interior finished and cleaned up the front bumper/winch. The flaking wheel paint is next on the list
Cleaning up just beautifully!
quick and easy door pocket fix. SEM flex coat dye
i masked off one and then used the same tape for the other three. Took about ten min to complete but maybe i should do another coat now that it has dried. This old nylon is really thirsty and it isnt quite as dark as the dye.
