KP's JW JP29 Build [Complete]
KPtheMP
Re: KP's JW JP29 Build
Post by KPtheMP » December 2nd, 2015, 10:49 pm
Yesterday I got the front motor mounts cut off, moved forward and welded to the 6cyl position (frame came from a 4 cylinder). You can see where the old mounts were compared to the new location
Installed new brakes while I was waiting on parts from amazon to arrive
new rubber body mounts showed up and were installed
once the body was bolted down using all new hardware, I did a quick test fit of all the front panels
Today I got the motor swapped over from the old body to the new with all new transmission and motor mounts. I also painted the firewall black after reviewing some stills and promotional pictures from JW.
got the skid cleaned up and installed with new bolts
KPtheMP
Post by KPtheMP » December 4th, 2015, 8:34 pm
Spent the last 2 days prepping for paint. Yesterday I got the windshield cut out and removed all the factory stripes/decals
spent today on body work and sanding, also applied new seam sealer where needed
I bought my sand beige paint and performance red yesterday. Tomorrow I hope to primer the body and work on sanding the trim, doors and tailgate (still waiting on rear hinges to arrive, USPS is extremely slow taking a week or more for priority mail to arrive).
KPtheMP
Post by KPtheMP » December 5th, 2015, 7:41 pm
Luckily the temperature warmed up just enough today and I was able to spray some primer to the main body, its starting to look like something...
Post by RustyRodder » December 6th, 2015, 4:41 pm
Wow, tahts awesome work so far!! Hope to maybe run into you sometime when I find myself and the jeep down south
KPtheMP
Post by KPtheMP » December 6th, 2015, 11:19 pm
RustyRodder wrote:Wow, tahts awesome work so far!! Hope to maybe run into you sometime when I find myself and the jeep down south
Thanks !!! sounds like a plan, nice to see a fellow MJ owner :)
Jurassic Vic
Instagram: Jurassic_vic
Post by Jurassic Vic » December 7th, 2015, 11:02 pm
wow you work fast
FOLLOW THE VLOG AND PODCAST
KPtheMP
Post by KPtheMP » December 7th, 2015, 11:10 pm
Thanks, and yes I do, kinda known for that among friends ;)
I was just about to post up...
KPtheMP
Post by KPtheMP » December 7th, 2015, 11:21 pm
Hinges for the tailgate finally showed up today after a postal delay. I was able to cut open the holes a little bigger on the top mount of the TJ tailgate to get a proper fit. The hinges are a used set of the upgraded HD version off a 95 YJ from eBay.
94 vs 95 hinge
Yesterday I had spent the night stripping the half doors and tailgate down to prep for primer.
I plan to primer and sand the doors, trim, mirrors, wheels, and tailgate tomorrow. Im waiting on a special package to arrive Wednesday, then lay down the sand beige paint later this week.
KPtheMP
Post by KPtheMP » December 8th, 2015, 8:36 pm
Taking advantage of the warmer weather once again, I rolled the Jeep back out side today. Fixed 1 small ding on each door, sanded them down then primered the doors, tailgate, mirrors and side trim.
drilled the holes for the ball mount of the antenna and test fit the bolts
Stuck the tail light on for mock up of the rear fog light location, picked a spot I liked and drilled 2 holes (wires and bolt) into the body for mounting (due to the increased weight of a larger metal light vs the smaller plastic and the fact that I will venture over rugged terrain, I opted to install the lights into the body for rigidity).
trim and mirrors, primed and sanded
Body primed and sanded, waiting for paint, will tomorrow be the day ???
KPtheMP
Post by KPtheMP » December 9th, 2015, 11:06 pm
Today was awesome ! My super special package arrived and I got it put together and test fit...
I found this light bar through the FB search bar. I looked high and low everywhere with no luck, so I tried FB and found an ad a guy posted about 6 months ago. I figured its worth a try, so I sent him a PM. The lightbar was located near a friend of mine about 9 hours away, so I had him go pick it up for me and ship it. I was like a kid at Christmas when Fedex showed up this morning :)
It was another nice day in middle Tennessee, so later I rolled the jeep back outside this afternoon and laid some sand beige on the interior and under the hood. I was a little cautious at first but after a few coats on the roll bar I was impressed.
Tonight I fixed a few rough spots on the lightbar and will primer them tomorrow as well as paint the complete body
