Jurassic Park Jeep #12
Boomerjinks
Re: Jurassic Park Jeep #12
Post by Boomerjinks » May 11th, 2010, 5:50 pm
Bestop doesn't make "OEM" hardware. Mine is from Rugged Ridge.
AJ Quick
Post by AJ Quick » May 11th, 2010, 6:43 pm
As far as I know, Bestop makes their own hardware... compared to OEM. They make tops that work with their own stuff, and make tops that work with factory hardware.
So you have Factory style hardware that is made by Rugged Ridge?
AJ Quick
Post by AJ Quick » May 12th, 2010, 12:46 am
Almost ran out of gas. I guess the gauge isn't very accurate?
It was sitting at 1/4 tank when I left and was around 1/8 tank when it started to stumble. It just barely made it to the gas station. Then I filled it up. Could only get 19.2 gallons in a 20 gallon tank. I would have expected it to hold 20.5 or 21.
Anyone know why a 20 gallon tank would start to run out at around 18-19 gallons? Is there a reserve valve? Is my tank full of sediment? Bad filter? Bad pump?
Post by Cyrix9445 » May 12th, 2010, 7:26 am
Oh damn, close one. I dunno why it would do that.
Jeepasaurus
Post by Jeepasaurus » May 12th, 2010, 8:31 am
My '89 is empy at one needle's width below 1/4 tank. Is your tank a true 20gal? I believe some tanks were 15 and there was a mod to covert to 20. Maybe not full 20.
Post by Cyrix9445 » May 12th, 2010, 9:18 am
Ah yea I've heard that, something about removing a tube to allow you to pump more gas. I believe the Saharas will take 20GAL from the factory though.
AJ Quick
Post by AJ Quick » May 12th, 2010, 10:07 am
Yep. All Saharas are 20 Gal from the factory. (atleast post 92).
Post by sahara93 » May 12th, 2010, 10:43 am
I dont think that the jeep gauges are very accurate
I know mine are a little crazy sometimes
chumpmann
Post by chumpmann » May 12th, 2010, 11:12 am
YJ's are notorious for the gauge being "off"
A few solutions,might look it up on jeepforum.com, but a couple I remember: Take off the dash and clean the connections, or worst case, replace sending unit.
Mostly I have heard to keep track of fuel using your odo. , just reset every time you fill up, you will know how many miles you can drive.
Mine goes empty around the 1/8 mark. I just dont let it get close.....
AJ Quick
Post by AJ Quick » May 12th, 2010, 11:39 am
How far can you go?
Should I just fill up at 300 miles?
Users browsing this forum: Bing [Bot] and 22 guests
