The Beginnings of my Jeep #12
- ScottWarrior
So that's where the winch went. Was saving up for it. Glad it went to one of us.
BlackAdder719
is that a rep6000? brand new! :Q
- ScottWarrior
Remanufactured 24 volt
- Zombierockstar10
Did you get longer Bolts to have the hooks under the plate?
Lex: I'm a hacker!
- jpsteve
It is a ramsey rep 6000 remanufactured 24 volt. For the toe hooks I just used the bolts that held the hooks in before.
- jpsteve
Here are a couple pics of my attempt at roughly copying Jeep 12 lights. Not perfect but they are close enough. Also found a set of half doors with Sahara Green door panels and pockets. Have a new soft top, Just need assembly now.
- 2.jpg (65.62 KiB) Viewed 30060 times
- 1.jpg (72.75 KiB) Viewed 30060 times
- heartyfield
Looking good! what type of brackets did you use to attach the brush guard to the light?
- jpsteve
Just some l brackets from home depot that I bent the way I wanted
- heartyfield
They worked out well! Been racking my brain trying to decide how I wanted to go about doing those. That and car trim vs. corrugated drainage pipe around the base.
- jpsteve
I just used 3 m tape for tge base. Not shown in the pictures.
