heartyfield
Post by heartyfield » June 17th, 2013, 10:48 am
Thanks and they're much appreciated!
heartyfield
Post by heartyfield » October 28th, 2013, 2:09 pm
Quick update: I found and bought a lightbar off of ebay. Ended up getting it for $15, but shipping was expectedly high at $65. All in all not bad for $80 total.
photo 1.JPG (102.33 KiB) Viewed 17853 times
I was able to sand, prep and spray the primer this weekend.
I also started on the mounting plate. I had an old sign that I really didn't care about so I cannibalized some of it to make the mounting plate. I've still got to cut it down to size and round the corners. It looks like the IOA pics show the plate only sticking out around > 1/4" from the outer tabs on the lightbar.
Here are the switches that will be installed eventually. As Cyrix and Jack have done, I'll adjust the wiring so that the controls move in the same direction as the lights.
AdamT
Post by AdamT » October 28th, 2013, 3:00 pm
Just a suggestion, for the KC HiLites on the back. If you really want to be nitpicky, you can take off the flip covers. It doesn't break the light and it is a little bit more cannon. Here's a picture of mine.
-Adam
Jeep Rear
Jeep Rear
heartyfield
Post by heartyfield » October 28th, 2013, 3:47 pm
Thanks Adam. I recently removed them and you're right, it does look better/canon. Once I get my spare tire finished I'll take an updated shot.
heartyfield
Post by heartyfield » October 29th, 2013, 8:41 am
After around 10 dremel cutoff wheels, I was able cut the radius on the mounting plate. I also marked and drilled all the holes for the search lights and for mounting the plate to the bar.
photo 4.JPG (110.47 KiB) Viewed 17843 times
Before mounting the two center Jabsco's, I checked for proper spacing. It's really awesome how things are looking and I can't believe things are coming together so well.
photo 2.JPG (121.92 KiB) Viewed 17843 times
Post by Jack_Fauth » October 29th, 2013, 10:08 am
looks really great so far, quick tip on running the wires through the lightbar. all 4 wires need to go through it and about the third wire i really had a hard time getting it the wires to move through the bar. apply some vasoline or WD 40 on the wires to help them not bunch up inside the bar.
Keep up the good work and keep the picture coming!!
heartyfield
Post by heartyfield » October 29th, 2013, 10:42 am
Thanks, I've definitely used your build for a lot of inspiration!
I've been wondering about how to pull those wires through and that's a great tip on using the lubrication to feed through the bends. My plan is to fish through four strings to pull the wires with. Hopefully with the added lubrication it won't be too stubborn, but there are a lot of wires.
heartyfield
Post by heartyfield » November 4th, 2013, 9:12 am
Didn't get as much done as I had wanted to this weekend. My Harbor Freight gun developed a clog that I couldn't find, so I had to go to the store and get another one. I had a 25% off coupon so I got it for around $11.00 and at that price, I can't really complain if they're one time use. One thing they changed is the fluid tip, which is now plastic, but I really didn't notice a difference in performance.
I stuck a couple stakes in the ground and sprayed the lightbar and mounting plate together.
I also sprayed the spare rim and the front of the sidesteps. I'm getting low on red, but I should have enough to finish the brushguards around the lights.
Target1992
Post by Target1992 » November 4th, 2013, 10:21 am
That is a big daddy long legs...
heartyfield
Post by heartyfield » November 4th, 2013, 11:06 am
Damn, I didn't see that. Should make a nice permanent edition to the paint.
