FL JP Jeep 18
Re: FL JP Jeep 18
Post by ImperialTrooper » January 29th, 2013, 12:03 am
How did water get into your air box?
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » January 29th, 2013, 12:15 am
i hit a 3 ft hole at like 15 mph and the splash i gess got in it and made the jeep stop and role out of the hole
Lex: I'm a hacker!
PaulRevere1991
Re: FL JP Jeep 18
Post by PaulRevere1991 » January 29th, 2013, 4:12 am
Yea, the intake is right behind your drivers side signal light, and it faces down. easy fix is to get the intake horn off a TJ and replace it with that, raises the intake about 4 inches, and it faces up. You have to make it fit, but its possible with a little work.
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » January 29th, 2013, 3:17 pm
Ya little deeper and i got a flexible 2" pipe with a 90 thinking about doing a cold air in take and fliping the air box so the holes faceing back and put tube from it to same in take as a/c
Lex: I'm a hacker!
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » January 29th, 2013, 10:24 pm
Well put my ball mount on to day and started to take the stripes off didnt get the weel i justed used a hair dryer and pulled it off took some time but hay its free
Lex: I'm a hacker!
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » January 31st, 2013, 11:19 pm
Just finished puting the Kc lights on the back still have to run a 12v power to the back tho the wireing harnes i got with um wasnt long enuff
Lex: I'm a hacker!
raptorwrangler
Re: FL JP Jeep 18
Post by raptorwrangler » February 1st, 2013, 9:37 am
What switch have you decided to use for the Back KC lights?
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » February 1st, 2013, 2:38 pm
i didnt see a pic of what was used in the movie so im going with the one from the box. but is there a pic showing the swich? if so were is it?
Lex: I'm a hacker!
Zombierockstar10
Re: FL JP Jeep 18
Post by Zombierockstar10 » February 1st, 2013, 2:47 pm
im thinking if i go fram by frame when (the blood sucking lawyer) turns to talk to Hammond comeing from the hela pad. will post pic if i find out wich one it is
Lex: I'm a hacker!
Users browsing this forum: No registered users and 40 guests
