It's more of a prototype. I'm having a hard time with the bubbles... That's what those dark spots on the yellow border are.
When I cast, I uses a vacuum and pressure chamber. Vacuum chambers aren't cheap (my vacuum pump was about $400), but I built a reliable pressure chamber using a Harbor Freight pressurized paint pot. If you want details, let me know. A decent shop compressor will be required.DrewSmith007 wrote: If I can sort out the bubble problem (it's not bubbles in the resin, but trapped air when I pour) I'll make a bunch.
