MY JP06
Re: MY JP06
The supertop has rounded upper doors and a different frame
Re: MY JP06
I mounted my rear amber lights today and printed out a rearveiw mirror tag, I still have to wire the lights in
Re: MY JP06
My Jeep initially came with a black supertop, and it utterly spoiled me. I could put that thing up and take it down in 5 minutes by myself, it was great. Then I bought Rugged Ridge OEM hardware and a factory top, and the soft top has been a royal pain ever since. My top is just way too tight, and I've tried just about every Jeepforum.com-suggested remedy there is. I even left the top on for two winters to stretch it, and I can rarely put it up single-handed after all that.yj87jp wrote:The supertop has rounded upper doors and a different frame
The Supertop may not be accurate, but holy crap is it a dream compared the factory hardware.
Re: MY JP06
Are you saying I should not invest a buttload of money converting to OEM, and instead change my Supertop color from black to Spice?Boomerjinks wrote:My Jeep initially came with a black supertop, and it utterly spoiled me. I could put that thing up and take it down in 5 minutes by myself, it was great. Then I bought Rugged Ridge OEM hardware and a factory top, and the soft top has been a royal pain ever since. My top is just way too tight, and I've tried just about every Jeepforum.com-suggested remedy there is. I even left the top on for two winters to stretch it, and I can rarely put it up single-handed after all that.yj87jp wrote:The supertop has rounded upper doors and a different frame
Re: MY JP06
If accuracy is not your game, and your jeep is your primary car, and if you already have the super top hardware, might as well.
Re: MY JP06
Those magnum hq's by chieftain look great. The KC's that are made now are to large to point downward so i am always afraid to drive with them on because of people behind me. I have thought about mounting a spacer under the base of the KC's but then the rubber boot would have a gap underneath. Hard to explain but how are those chieftains mounted? To the tail light housing or to the jeep itself?
Re: MY JP06
I'm with boomer on this, it is so quick to get on and off on your own & you can do full & halve doors if its your daily drive (mine is). I've just swapped my black one for a brand new spice. Now me being silly and attempting it factory fresh and about 7deg C it was a bugger! But I did it on my own and will fix when I can get heat on it. Only we would know the difference of the tops, I think most people who see it are bedazzled by its a JP jeep anyway to notice.ImperialTrooper wrote:Are you saying I should not invest a buttload of money converting to OEM, and instead change my Supertop color from black to Spice?Boomerjinks wrote:My Jeep initially came with a black supertop, and it utterly spoiled me. I could put that thing up and take it down in 5 minutes by myself, it was great. Then I bought Rugged Ridge OEM hardware and a factory top, and the soft top has been a royal pain ever since. My top is just way too tight, and I've tried just about every Jeepforum.com-suggested remedy there is. I even left the top on for two winters to stretch it, and I can rarely put it up single-handed after all that.yj87jp wrote:The supertop has rounded upper doors and a different frame
Re: MY JP06
I mounted the lights to the tail light housing but I am going to move the passenger side light over some because of the stupid metal plate inside the housing I ended up busting a reverse bulb in the process.
Re: MY JP06
I encountered the same issue, but now I can't remember how I fixed it... lol
Re: MY JP06
Finally got my rear lights wired in and they are stunning, the wiring was a pain though.
