Pennsylvania Jeep #12
Re: Pennsylvannia Jeep #12
Post by Jack_Fauth » December 14th, 2011, 9:47 pm
can't wait to mess around with these tomorrow in the dark...!!!!
mydigitalvoid
Post by mydigitalvoid » December 14th, 2011, 10:25 pm
Where did you mount the switches on the inside?
Maverick20
Post by Maverick20 » December 15th, 2011, 7:59 pm
what about the inside of the light bar how did u stop rust?
1995 YJ Sahara
Post by Jack_Fauth » December 15th, 2011, 9:49 pm
Maverick20 wrote:what about the inside of the light bar how did u stop rust?
I think the bar will be fine as it is, mine has zero rust on the inside.
as for mounting the switches i ran each lights wire through the hole in the back of the bar near each mounting tab.
then i drilled a 1" hole into of the side of the jeep that goes into the passenger compartment. Then i ran all 4 wire through a grommet and into the interior compartment.
Here you can see that i mounted the switches to the oh shit bar above the glove box
Ran all 4 light to the accessory switch in the fuse box under the dash. LightS all run indepently as they did in the movie
here is a photo of the switches mounted. I think i will get a blank cover to fill in the end and hide the rest of the wires
Last edited by Jack_Fauth on December 23rd, 2011, 9:40 am, edited 1 time in total.
Post by Jack_Fauth » December 15th, 2011, 10:11 pm
MONEY SHOT......!!!!!!!!!!!!!
Post by fantomas » December 15th, 2011, 10:38 pm
Holy crap that looks great! When you test it out, let us know the actual functionality of those lights are.
On a side note, I've got that same Ikea lamp
PaulRevere1991
Post by PaulRevere1991 » December 16th, 2011, 12:05 am
looks awsome
Breven52
Post by Breven52 » December 16th, 2011, 12:40 am
I actually just had an idea for your glovebox delete pannel. you should try to do a Data plate for it. Until the late run of Cj5s, jeeps came with acid etched Data plates. IImage
here are some samples I made
04' Wrangler Sport
42' Ford GPW
Jedigreedo
Post by Jedigreedo » December 16th, 2011, 1:37 pm
Awesome work, Fauth! Looks fantastic!
And nifty idea, Breven.
"We came, we saw, we conquered, we... woke up!"
Maverick20
Post by Maverick20 » December 16th, 2011, 11:35 pm
cool nice light bar im powdercoating mine the only thing im a little lost on is how to wire the lights up. like relays fuses and all that.. i know how to do butt connectors and stuff like that. just dont undersatand the route and where i need to run it all. mine will be non-morotized 55w each 4 lights.
1995 YJ Sahara
