I wouldn't trust a 3000 lb shackle if you have to pull it.. the jeep stock curb weight was 3080 lbs for a sahara.
yeah i would not use them for any kind of towing or recovery they woud be good enough for if you need to put the jeep on a trailer or something that is all that i would use them for
sahara93
Yes that is the correct paint code.
If you have a rub on or spray on promoter that should be just fine. There should be a flexer that is mixed into the paint to make it flex with the plastic not crack and chip off. You probably would have used it on your fender flares and running boards. when I bought the green paint for the panels it came mixed in the paint. You can also add it if you like.
Cheers
Vince
Cheers
Vince
For recovery i would need a chain to run between the two and pull from the center. If they are good for 3000 lbs a piece then that would be 6000 lbs total. I dont think they would ever be used for anything more than a tie down anyways because i have a winch. Lets focus more on the looks. Yay or Nay?
- DrewSmith007
I say keep 'em. I do like the red pins as well.
I agree with Drew. They look cool to me too.DrewSmith007 wrote:I say keep 'em. I do like the red pins as well.
1993 Jeep Wrangler Sahara
JP #21
JP #21
- Boomerjinks
I'm not a huuuge fan. If they are just for looks, why bother? It's like the obnoxious dudes that keep the giant hi-lifts on their hoods when their Jeep is a commuter vehicle for all but two weekends out of the year.ratrace427 wrote: Lets focus more on the looks. Yay or Nay?
I was using the fog lights tonight and the head light switch got really hot. Dang! Ever car that i have owned with factory fog lights have this problem. The head lights actually turned off and on several times. Looks like i need to get a new switch and put a relay in the mix somewhere. Anyone else have this issue ?
- ImperialTrooper
Do all your lights go out? Interior and main headlights as well? If so I have the same issue, that's why I never use my fogsratrace427 wrote:I was using the fog lights tonight and the head light switch got really hot. Dang! Ever car that i have owned with factory fog lights have this problem. The head lights actually turned off and on several times. Looks like i need to get a new switch and put a relay in the mix somewhere. Anyone else have this issue ?
Oh i dont know. It happened twice back to back and didn't notice what the instrument lights were doing.
