- spike42718
If I cant find one in the next few weeks, Ill be ordering this one. Like you said I could easily shorten this one.
MN-cherokee
demoran wrote:I bet you the TJ one is so tall since it has a fixed header in the top that would need to clear to fold back. The CJ/YJ one probably doesn't have that weird cant and probably is shorter.
I don't see why you couldn't cut/sleeve and re-weld it. If you were closer I'd offer to weld it for you.
Exactly what I was thinking. The YJ top wouldent need nearly as much room to remove the top. Even if it didnt come apart like the Mopar one cutting and welding it would be no big deal.
- spike42718
From Joop to Jeep in 20 minutes!!!! I know i'll be pealing these off this fall when I paint the jeep, but until then they will make it look better.
- joop.JPG (20.01 KiB) Viewed 25240 times
I need some jeep decals to finish off my jeep
Where did you get your Jeep decals and how much, I also need some
1994 Jeep Wrangler
That light bar hasn't been made in years. It does not look like that anymore.. here is what it looks like:MN-cherokee wrote:That looks just like the Mopar one. Which was probably made by Olympic for Jeep.
It looks a little tall, but it looks like it comes apart and could probably be shortened.
The picture on the page shows it on a TJ. Its possible the design is slightly shorter for a YJ. Either way it looks lke it might be a good substitute and I may be ordering one. Price is not bad at all.
Seen here: viewtopic.php?f=9&t=223
- spike42718
damn that sucks, I was hoping to order it tomorrow.
MN-cherokee
Looks like its back to building one for me. Unless I find one it should not be that hard. Just get a piece of tube bent and weld on some flat plate for the mounts.
- spike42718
http://cgi.ebay.com/ebaymotors/Jeep-wra ... ccessoriesdan85 wrote:Where did you get your Jeep decals and how much, I also need some
Guy sent me two for the side, and 2 smaller ones as a free gift. Im sure I'll put them somewhere. I got orange to see what it looked like cause some people say the JP jeeps have tan. I think orange looks closer.
- spike42718
Havent had time to post in a while. Have been having crank sensor issues but managed to get some stuff done. Got a borla muffler and a magnaflow hi flow cat, found the wheels I need, got my whip installed, and installed HID headlights (spared no expense) also managed to pick up a small amount of the paint I will be using so I could decide if Im going flat or glossy. Still haven't decided. Check out the storm coming my way, first time time in the rain with the wrangler!!!
- whip2.JPG (109.61 KiB) Viewed 25183 times
- HID.JPG (71.27 KiB) Viewed 25183 times
- Exhaust.JPG (79.36 KiB) Viewed 25183 times
- Whip.JPG (80.41 KiB) Viewed 25183 times
Users browsing this forum: Bing [Bot] and 15 guests
