Jurassic Park Jeep #12
AJ Quick
Re: Jurassic Park Jeep #12
Post by AJ Quick » May 14th, 2010, 1:06 pm
Just taking a break.
I took the top off, and the doors.. and then went to go pick up some Herculiner. Pretty fun. Although door-less driving really isn't for me. Heck top down was annoying because you have no privacy. :lol: At the auto parts store there was a same year Jeep Renegade with their top off and no doors. Copycat.
I also got a few items in the mail today. Mainly my new windshield frame and Sahara half doors. The doors need a few parts and an alignment before they will fit right. But its so nice to have some half doors.
Now to go strip the interior. I already took a peak at the driver side floor, and it is pretty rusty. I hope there are no holes and it is thick enough to use. I hope I don't have to replace it.
cklinejr
Post by cklinejr » May 14th, 2010, 1:52 pm
Wow, your really making some awesome progress.
Keep it up.
Post by sahara93 » May 14th, 2010, 2:55 pm
did you find color accurate sahara half doors?
thats something you dont see everyday
AJ Quick
Post by AJ Quick » May 14th, 2010, 2:58 pm
sahara93 wrote:did you find color accurate sahara half doors?
Fortunately.
Except they are from a 94 and Dark Green. But have accurate door panels.
Post by sahara93 » May 14th, 2010, 8:33 pm
man
i wish i had found those a year ago for my other jeep
i just got normal half doors then painted them then i found some door panels but they were all cracked so i just stole the pockets off of them
then the jurassic park jeep came with half doors then i painted them the right color and then painted the panels the dark green and got the pockets made
AJ Quick
Post by AJ Quick » May 14th, 2010, 8:35 pm
Well I did have to pay $450 for them.
But that price might not be so bad compared to all the work you had to do.
Post by sahara93 » May 14th, 2010, 10:33 pm
i think i paid 300 for the doors then 250 for the paint so i did pay more in the end
AJ Quick
Post by AJ Quick » May 14th, 2010, 11:05 pm
The UPS man came today with a few presents from eBay. The first is a set of Half Doors from a 1994 Jeep Sahara. They will be right at home on my 1993 Jeep Sahara. They are the wrong color (a shade of dark green), but the door panels are correct and they have the screen accurate pouches. Only cost $450! (ouch!)
Also in is a new (used) windshield frame from a 1989 Jeep. The glass is cracked and is in the process of being removed. It is virtually rust free, except for a few marks of surface rust that will be easily neutralized. A nice catch for only $180 shipped. (about the same price as a cheap aftermarket windshield frame).
AJ Quick
Post by AJ Quick » May 14th, 2010, 11:07 pm
Today was a big day for progress on the interior. It was decided that I would be stripping the inteior and laying down a layer of Herculiner to hopefully subside any eventual rust on the body. The Jeep is in such a great shape that we were hoping for the best as far as hidden rust spots were concerned. After the doors and hard top were removed the first step was to remove the carpet and rear seat. This is a very easy task, its just a lot of fishing carpet around mounts and removing bolts.
When it came down to removing the rear seat, the first level of resistance was reached. Three out of the four bolts holding the front of the rear seat down snapped off. And they snapped off nearly flush with the surface. Getting them out will be still one of the hardest things to do.
Moving foward into the Jeep the front seats and carpet are removed. Here you can see the first glimpse at the floor rust. Like the rear seat there was some issue getting out the front seat. Two of the bolts proved to be rather difficult to remove, but came out after some finessing.
The rust on the driver side floor pan was initially viewed as horrible surface rust. As we chipped away at the rust, it was obvious that the floor would need to be replaced. There should be plenty of solid metal to weld a new section of sheet metal in place. Normally I would weld in a replacement panel, but I would much rather have this done over the weekend and not push the project back into the next week.
The rollcage bolts have been removed in the rear, and the cross bar was removed with the sound bar. Unfortunately four of the front bolts on the rollcage were sized, and stripped out several Torx sockets. We could not apply enough torque on the torx to remove the bolts. The solution was to purchase several cheap Torx sockets and weld one to each bolt. With a much larger cross section making contact with the bolt they broke loose easily with a 2 foot breaker bar.
T-rex23
Post by T-rex23 » May 14th, 2010, 11:12 pm
Very nice, I love watching everyone's progress, what are you using for your main color?
Users browsing this forum: No registered users and 44 guests
