Gas Powered Jeep - JP 14 - Dr. Harding Vehicle
nmlvaio101
Re: Gas Powered Jeep - JP 14 - Dr. Harding Vehicle
Small update.
I ended up buying the fog light kit on eBay. Ari and I are going to archive it for historical use.
nmlvaio101
nmlvaio101
nmlvaio101
Some notes about the Besttop hardware and Softtop.
So, I just got off the phone and I am still confused by the process. The following is my understanding of process.
The sales operator meantioned there is two ways to achieve the effect: 1) cheap or 2) more expensive way.
A) Cheaper:
1) SuperTop Classic Squareback Soft Top (SKU: 5159901) - This includes both hardware and canvas minus the door hardware and canvas ($949.99
2) Upper Fabric (SKU: 5178001) - Need to select "Rounded Upper Rear Corner" that fits Supertop Classic 54599, 51599 - This includes the door harware and canvas ($444.99)
B) Expensive way (more screen accurate just more parts on hand:
1) Replace-A-Top for OEM Hardare (SKU: ???) - This is the complete canvas set to include upper door. You may select between original 'spice' or the 'Spice Sailcloth' in whihc is a heavier fabric. "This premium, multi-ply fabric helps reduce road sounds, absorb wind noise, and keep interior climate more consistent than dual-ply fabric" ($609.99 - Spice or $75.99 - Spice Sailcloth).
2) SOE Style replacement Bow and Frame Hardware kit (SKU: 5500401) - This includes everything minus the door hardware ($534.99).
3) Upper Fabric (SKU: 5178001) - Need to select "Square Upper Rear Corner" that fits original factory hardware or Replace-A-Top ($444.99).
I could be wrong here and there. I need to revisit this down the road and update the above script.
A) Cheaper:
nmlvaio101
Small update:
Found the screen accurate RadioShack spring with another cb radio ball.
The following is my final item inventory list to find/buy:
1. Spare tire cover
2. Winch cover
3. Overhead light cover (custom made)
4. Door panel (temp)
5. Door panel retaining pin (temp)
6. Door panel pins
7. Mirror (left and right)
8. 2- way switch console
9. x2 fog light switch
10. Soft top and hardware (Besttop)
11. Ko2 tire
12. Hitch
13. Valley hitch
1. Spare tire cover
2. Winch cover
6. Door panel pins
11. Ko2 tire
12. Hitch
13. Valley hitch
Red5
- Facebook Profile URL: https://m.facebook.com/Jurassic-Jeep-20 ... =bookmarks
Are you on the Facebook motorpool workshop?
nmlvaio101
Users browsing this forum: No registered users and 60 guests
