JPRunner's 2000 Toyota 4Runner build
Re: JPRunner's 2000 Toyota 4Runner build
Got the side numbers done. She's pretty much done. I sure get lots of looks and folks taking pictures all of the time
- fifthrider
I'm glad you did that red stripe on the underside of the driver's side. It looks cohesive.
yeah, not sure about that though. I did it under the driver's side door (but not the passenger side) and I noticed that it's already peeling off from getting kicked when I get in and out. probably will peel it off.
as to the truck I'm still working on a few small things. will probably get a cattle prod and animal control pole to put in it when I park outside a convention or other venue. so that'd give me (on the inside):
- Park ID badge
- Shotgun
- Gear case with flares & flashlight
- cattle prod
- animal control pole
- JP rain slicker
and I'm still working on other ideas for little tidbits to put on the inside. I'm also going to eventually get a replica raptor claw fossil and hang it from the rearview mirror.
- Park ID badge
- Shotgun
- cattle prod
- JP rain slicker
not sure on the flexidip , but the plastidip was easy-ish to mess up for a while after applying - but once its on a while it stays on pretty darn well.
